Test Setup
Because of the CPU cooler height limitation on this case, our standard ATX test kit is unsuitable, so we've had to use one of our small form factor test systems. We have two near-identical but physically different systems with which to perform thermal tests. The key difference is the height and design of the CPU cooler; one system uses a low-profile, downdraft cooler while the other uses a tower cooler, albeit a rather short one, with a standard front-to-back airflow. We test each small form factor case with the appropriate system depending on the cooler it can support. While this does mean you'll see mini-ITX cases compared to micro-ATX ones in the same charts, it allows us to test cases with the cooler style they were designed for, which is important for air-cooling.
As this case does not support tower coolers, we're using our low-profile small form factor case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at full speed while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use CoreTemp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Cooling Performance
![](data:image/png;base64,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)
![](data:image/png;base64,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)
